Test Setup
Because of the CPU cooler height limitation on this case, our standard ATX test kit is unsuitable, so we've had to use one of our small form factor test systems. We have two near-identical but physically different systems with which to perform thermal tests. The key difference is the height and design of the CPU cooler; one system uses a low-profile, downdraft cooler while the other uses a tower cooler, albeit a rather short one, with a standard front-to-back airflow. We test each small form factor case with the appropriate system depending on the cooler it can support. While this does mean you'll see mini-ITX cases compared to micro-ATX ones in the same charts, it allows us to test cases with the cooler style they were designed for, which is important for air-cooling.
As this case does not support tower coolers, we're using our low-profile small form factor case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at full speed while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use CoreTemp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Cooling Performance
![](data:image/png;base64,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)
![](data:image/png;base64,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)
